Rear pad replacement for 99 Honda Accord
I am trying to replace my rear brake pads on a 99 Honda Accord w/ Vtech Engine. (disk brakes)
First time doing so on this vehicle.
Do i do the rear just like i do the front? change pads, c-clamp caliper?
Any help?
Any help?
First of all, you misspelled VTEC. Second, this topic has been covered tens of times and can easily be found by using the search function and typing in 'rear pads' or 'accord brake pads' or something like that.
https://www.honda-acura.net/forums/s...ord+brake+pads
I'm sure there are even more...
Originally Posted by flyromeo3
not to sound like a dick or anything but its even labeled in the valve cover.
Usually I make some smart ass reply related to a picture like this :chuckles: :
Any help?
Any help?
I'm sure you'll find some info if you search, but don't use a c-clamp on the rear, you'll need to rotate the piston in. You can use the special tools they make for that, or you can use a large flathead screwdriver.
The info I posted in the first link that 98coupeV6 posted pretty much should do it: https://www.honda-acura.net/forums/s...ord+brake+pads
thanks for the tutorial on spelling V-tec
I think i got it know!!
I did find instruction on replacing rear pads
Thanks for the help and links.
Oh, and for clarifying V-tec for me....
