I Have a Problem With the spark plugs!!! help please!!!!
Old 08-07-2005 | 09:24 AM
katraloko's Avatar
katraloko
Default I Have a Problem With the spark plugs!!! help please!!!!
ok I did change my spark plugs on a Honda Accord LX 1991.... but when I took them off I forgot the rotation!!!! I mean the longest cable is #1 so in what hole does it go??? cable #2 (the next one) #3 and #4??? anyone can help me??????????
Old 08-07-2005 | 09:27 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
:doh: this is why you change your spark plugs one by one
In every car I've ever seen, the spark plug cables from the distributor are all different lengths - so pull them all out, and compare their lengths. Obviously, the longest one goes into the cylinder farthest away from the distributor and the shortest one belongs to the cylinder right next to the distributor.
edit: and while you're at it, change your PCV valve if you haven't in awhile and suck some seafoam into that puppy unless you've cleaned out the intake manifold in the past 30k miles. That's my every 30k maintenance ritual And welcome to HAN!
Old 08-07-2005 | 09:46 AM
katraloko's Avatar
katraloko
thank u............. I just get that car and the guy who sold it to me told me that it has a bad sensor the problem is that he doesnt know which one is!!! anyways I guess its really fuck up but ill take it to the computer anyways thank u man!!!!
Old 08-07-2005 | 10:11 AM
98CoupeV6's Avatar
98CoupeV6
Is there a check engine light on? If there is we can help you find out exactly what is wrong with the car. The sensors that typically go on Hondas are the oxygen sensors, which can get pretty expensive and help the engine to provide the correct amount of fuel to the combustion chambers.
If there's no check engine light and the engine runs fine and you get proper MPG, maybe there isn't a problem at all.
For reference: In the F23 (the 4 banger in the 98-02 Accord), the #1 cylinder ignition wire goes in the bottom left plug in the distributor and 2-3-4 go counterclockwise to it. I bet all Honda 4 cylinders with distributors are the same.
Old 08-07-2005 | 02:30 PM
katraloko's Avatar
katraloko
ok I get the spark plugs right!!! I found a pic in the internet n I get it!!!! now my uncle told me that the transmition is fucked up!!! and theres no lights on....so i dont know now ima try to get the transmition thank u man
Old 08-07-2005 | 02:54 PM
VTEC-Power's Avatar
VTEC-Power
Does it feel like the tranny is messed up?
Old 08-07-2005 | 04:15 PM
HallKemar's Avatar
HallKemar
post me a link of that picture you found....
