if my automatic transmission will not engage or shift into any gears any more?
do i need a new torque converter or do i need a whole new transmission
because it was working for about a month but it was slipping bad
eventually
i wont move any more at all
before i could feel it slipping really really bad
now it wont engage at all
eventually
lots and lots of fail
1 Post
that has nothing to do with the torque converter. That's an issue with the hydraulic clutches within the transmission. To learn how automatics work, www.howstuffworks.com is a very good site.
You'll need a whole new tranny. I drove on my first one until I had to manually shift gears (and let off the throttle for 2-3 seconds between each one) for a couple of days. First and second were only occaisonally engaging. That sucked.
In the depths of my mind
If you have a 6th gen v6 like I do, you'll need a whole new tranny. Mine started slipping and wouldn't engage until a certain RPM (beyond the normal range) was hit. Then it would shift really hard and lose a lot of power. You're best bet is to change it ASAP and not wait. I waited a while cuz i thought the problem was minor...boy was i wrong.
my friend said that its probably because the seal is torn or worn out and it lost pressure
is that something that maybe true the seal rips a little and u loose pressure?
1 Post
It could be a bad modulator valve that controls the pressure. I've never heard of one going but I suppose it's possible, so measure line pressure.
Or it's one of these problems:
Or you should just buy a new car or a new tranny.
