90-96 accord conversion help
well i need some help here, i am have put a 96 motor into a 90 body, but i am stuck.I dont know what to do with the ecu, how do i convert the harness to make it use the odb2 ecu. I am also having problems with the mounts the engine is lean, i need some advice with the rear mount,do i take off the rear mount or bracket and wat do i use. i would like to drive the car for the summer, june is here already, any help would be greatly appreciated. thank you guys.
well, they do have conversions wire harnesses for the obc and shit
as for the ngine, i thought it bolts right in? unless of course it is a manual on a auto tranny or vice versa, then id assume one would have to get the right mounts.
post up on cb7tuner.com
im sure they could give you some quik ass answrrs.
