Rear brake job - accord ex 2000
Originally Posted by jschmid
Well aren't you thorough?
ok - thanks for all the help from everyone. I appreciate it!!!!! Im DONE. I hope I did it correct, I test drove and everything seems ok. I saw on the pic that there was shims on both pads, but when I took them off the was only pad shims on the outside pad not on the pad on the inside. Should I be concerned???
Did you remember to line up the bumps in the pad with the slot in the piston?
The first time I ever did rear brake pads I guess I didn't line them up correctly and when I went to change them again the pad and metal thing completely seperated. As long as everything is tight though it really shouldn't be a big deal, it's just more of a 'just in case' thing. I wouldn't worry about it.
I am pretty sure I did it right, but thanks again for all your help. I really do appreciate it. I would not have been able to do the job if you had not helped.
Oh yea, any thoughts on why my SRS light might be on? how much to fix best/worse case?
scott
scott
scott
scott
