Do i need it again Help
Old 04-21-2005 | 05:13 PM
LakiTT's Avatar
LakiTT
Default Do i need it again Help
My car is 04 coupe V6 lowered on tein basic with about half a finger gap on each corner. I just had my car aligned last week, i need to lower the back about half an INCH more about a finger, do i need to have another alignment? I have ingalls rear camber kit, right now the camber is set to 1.20 degree L/R after alignment.
Now after i lower the back more,will that small amount drop set the camber, toe, caster off a lot from the setting i have now????
Reason im lowering the back more is because of bad handling, i actually lowered the front more than the rear.
Old 04-21-2005 | 05:22 PM
flyromeo3's Avatar
flyromeo3
dont TEIN basic lower your ride no more than 1.5 inches?
If so, I dont think you even needed an alignment.
Old 04-21-2005 | 09:49 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You should be fine.
I don't see what lowering the back 1/2" will do for handling. The front should be a little lower than the back anyway. Have you considered that the handling might not be because of the ride height but rather that it is not built for handling? Have you considered a thicker sway in the back?
