Adjusting 95 Accord low beams left/right
I just installed some starlight low beam lights and for some reason the drivers side light points off to the right too much. Does anyone know how to adjust the lights left to right? There is a screw that looks like it makes them go up and down and then behind the light housing there is a big spring with a slot ontop of it. In the bottom of the slot it looks like a small gear. I'm thinking that might be the adjustment, but if it is, how are you supposed to adjust it and with what tool. I tried using a flat head screw driver and i got the gear to move slightly but didn't notice the headlight moving.
