00 accord v6 coupe help
Can someone give me directions on how fix the clock? It seems like the light bulb is dead, its really annoying not being able to see the time at night. And also does anyone have or know where i can downlad the pdf version of the manual? Thanks in advance guys.
How to Replace bulb
The clock and emergency switch is held in by clips, to remove it just work your finger nailes in on the sides in the seams and wiggle it out. Once the clock and emergency switch are out, the bulb can be removed from the back by rotating it, it shows on the back which way to turn it. You can get a new bulb at a Honda dealer. You may have to unplug the cables to get room to work.
Mike
Mike
