Help buying light bulbs??
Old 02-20-2005 | 08:05 PM
abocic's Avatar
abocic
Default Help buying light bulbs??
hello all, can anyone tell me what kind of light bulbs will fit in a 2004 accord, the honda dealer tells me that the piaa bulbs will not fit because they are to long. is this right? and so what kind should i buy?
thank you
Old 02-20-2005 | 10:07 PM
TrackMasterz's Avatar
TrackMasterz
9006 sylvania silverstars - low beam
9005 - high beam
--some say silverstars are good, others think they burn out too fast ...ur choice
Old 02-20-2005 | 10:46 PM
Project_ITR's Avatar
Project_ITR
piaa's are the best i've ever used
Old 02-20-2005 | 11:07 PM
ericjackson's Avatar
ericjackson
9005 - high beam
:werd: i love mine. and i dont have a problem with them burning out quick.
Old 02-21-2005 | 07:57 PM
abocic's Avatar
abocic
i would like to get piaa's but the honda dealer here says that they dont fit on 03-04 accords. so im trying to find out which ones will fit. i was look at the piaa extreme force 4700k
Old 02-21-2005 | 10:18 PM
SecretChopSuey's Avatar
SecretChopSuey
I really like the output of the silverstars, but they do burn out quick. Mine personally burnt out around 6 months with moderate use of them. Do these piaa's have the same output?
Old 02-21-2005 | 11:33 PM
CalBearz24's Avatar
CalBearz24
my silverstars burned out within 8-10 months of moderate use. i did the 9005 conversion, though. i switched three family cars to 9005 GE superblues ($20/pair vs 40+/pair of silverstars) that have all lasted a year (one set is near 2 yrs now, i believe) and output bright white light.
Old 02-22-2005 | 02:54 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
thank you
If you want to upgrade your headlights, either get HIDs or modify your high beams to fit in your low beam slots. Aftermarket bulbs burn out waaaay too quickly for my taste.
Old 02-24-2005 | 02:00 PM
elton_hsu's Avatar
elton_hsu
i had a set of PIAA 5000k, one of them burned out couple months after i started using them.
Old 03-01-2005 | 05:51 PM
Project_ITR
i've had my piaa's for almost 2 years now
