Gas Tank Capacity?
Old 01-13-2005 | 11:19 AM
wil4713's Avatar
wil4713
I do that a lot, too...btw, what kind of mileage (mpg, that is) do you get? Last spring, I was getting like 31-32 pretty regularly (I drive on the highway a lot), but now I get ~28 or 29, even on all-highway trips in my 5-speed 95 ex.
The only things different about my car since then:
Changed tires to Goodyear touring radials (from stock(?) or stock replacement(?) michelins)
Changed timing belt
Switched from using 5w-30 to 10w-30 oil
Are any of these enough to make my mileage go down that much, or is there something I can do to increase my mileage to the previous levels?
I keep my tires well inflated and my driving style is pretty constant, too. Just wondering.
Old 01-13-2005 | 11:43 AM
mayonaise's Avatar
mayonaise
Changed timing belt
you're lucky you're getting that kind of milage to begin with. i haven't been able to get more than 26 unless 75% or more of the tank is used on highway driving... 95 ex 5 speed
Old 01-13-2005 | 11:48 AM
92lx
Guest
Posts: n/a
best way to measure gas mileage (while not entirely accurate, but pretty close), is to drive till the tank is empty, fill it up and drive till it is empty again, then divide the number of miles by how much fuel you have to put back in it to make it "full" again. The "E" light comes on, on accord's with either 1.5 or 2 gallons remaining in the tank.
- Nathan
Old 01-13-2005 | 01:54 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
- Nathan
Are you a statistics major?
wil: As cars age the mpg naturally goes down b/c the engine becomes less efficient. All you can do is keep up with basic maintenance, clean out your engine with Seafoam, keep your tires infllated, use your A/C as little as possible, keep your windows closed, etc etc
Old 01-13-2005 | 11:26 PM
strykernyc's Avatar
strykernyc
yes 40miles not 400 this suck, i try using the subway as much as i can but sometime i just wish i can just walk to my job traffic here is bad very bad . tonight coming home the guy walking the bridge was faster than the cars. i do 400miles on a full tank in the highway like from here nyc to mass.
Old 01-14-2005 | 07:44 AM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
Originally Posted by mayonaise
my 5th gen burns through the first quarter tank real slow. i usually get around 120 miles before the needle hits the 3/4 mark. the second quarter is quicker. i'm lucky if i reach 200 miles before i hit the 1/2 mark. the third quarter is about the same. the needle usually reaches it at about 260-275 miles. then the last quarter tank on the gauge is pretty slow, and i'll get about 80-100 miles on it. i typically get about 350-370 miles on 13-14.x gallons, and rarely let the gas light turn on.
so to recap....
1st quarter: 120 miles
2nd quarter: 80 miles
3rd quarter: 60-75 miles
4th quarter: 80-100 miles
pretty screwy..
Gas guages are notoriously inaccurate. Many manufacturers intentionally set it so that your gas gauge makes it seem like the first half takes longer to burn through than the 2nd half.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old 01-14-2005 | 12:17 PM
SecretChopSuey's Avatar
SecretChopSuey
I believe that cars get crappier gas mileage during the winter, and better mileage during the summer...something about the temperature. but who knows there is just so many factors that goes into mpg.
Old 01-14-2005 | 02:01 PM
Mr Hyde's Avatar
Mr Hyde
Correct. Some places winter gas which is oxygenated. Typically these fuels leave a little hit in MPG. I always notice it every fall/winter here in NY.
Old 01-14-2005 | 02:47 PM
98CoupeV6's Avatar
98CoupeV6
In the midwest it's ethanolized
Old 07-13-2005 | 06:21 PM
asnlc's Avatar
asnlc
i got a question. i just got my 97 integra almost 2 months ago. the other day, i was running low on gas (but the light hadn't lit up yet). however, when the light finally lit up, my car died. it was probably only the 1st or 2nd time the light when on, and i wasn't even on an incline (i was in a parking lot, might have been going over a speed bump tho). i believe at that point, i should have had 2 or 3 gallons left (13 gallon tank). is there something wrong with my tank that would cause my car to die right when the light turned on? the gauge was close to E, but hadn't hit the E yet.
thanks.
