My light came on just past the 1/4 mark. I had around 4 gallons left. First tiem it happened ot me in this car so I got gas at the next available station. I'll go a little further next time.
i run on E so many times because the gas price is diff like every other day. sometimes it take $27 to fill it up and other times like $35, everyday is like a diff price. this is super.
Same here. My car takes roughly 13-13.5 gallons to fill up from 'empty' All Accords (or at least since the 4th generation than I'm aware of) have 17 gallon tanks (including the 4 gallon reserve) Most all gas guages are designed to read 'E' a few gallons before the tank is completely empty... hence the reason the needle tends to move faster from half to 'E' than from 'F' to half. In any case, as someone mentioned above...never let your tank run dry. You'll burn up your fuel pump.
i thought 4th gens had 16 gallon tank. and from personal exp, from roughly 1/4-1/3 of a tank left is about 3 gallons or so before the light comes on. once the light comes on, i have no clue, cuz i dont like to push it that much
