Low Battery?
Low Battery?
Hi guys,
Yesterday evening, I drove to the local store and left my car on outside. ( remote start thing ) When I got back in the car my dash lights, radio on, headlights(HID ) and fog lights( regular ) etc.....was very very dim. So I gave her a little gas and everything lit back up normal. While I gave her gas the maintenance light came on for like 1 second then turned off.
I then go to my friends house and while im waiting for him outside I notice the same thing is happening. When he gets in my car I go to drive away and the car kinda like rev'd really low when i shifted to Drive as if it was about to stall. Also the maintenance light came on again for about 1 second.
We drove around yesterday and I didnt experience any problems afterwards. Im thinking since it was raining the belt probablygot wet and was slipping on the pully.
Today I drove around and everything was fine. No problems.
MAtter of fact, last night I took a brush and cleaned my positive terminal cause it was corrodied. Think that could of been the problem?
sorry for hte long post. Tryin to be descriptive
Originally Posted by 2kAccord
That sounds more like an alternator or ground problem. The only time its really a battery problem is when it wont start, or you have a really loud system that draws too much from the battery.
When a car is running the battery will stay charged unless it is not getting the proper power from the alternator which means it is more likely that your alternator is going bad.
Alternator
even though it hasnt happend again? Also i found in the manual that if there is a problem with the alternator charging etc....the light will illuminate.
That did happen.
Sorry I was drunk......The Light did NOT come on. The battery light did NOT come on.....lol..
That did happen.
I overheard from someone that you could put a grease or something on the terminal to prevent corrosion.
I have stinger battery terminals and was told since they are made of aluminum or whatever material it is ( non -OEM ) that i shouldnt put anything on it. true?
