early gen accords: driver side power window problem
i know this issue has been covered already since its a common issue among older accords. my driver side window on my 1990 accord ex sedan isn't working anymore. at first it would go half way and make a noise, then now it doesn't much or make a sound at all. i was thinkin is it possible to switch the motor with a motor from the rear windows?
Motor or the window rails, its a very common problem with all early gen Accords like you said. There really is no fix for it, I've tried everything and its only worked temporarily. I don't think the rear power window motors will work. Just get one at a junkyard or ebay, they are really cheap ~15 bucks or so.
