Turn signal noise
Old 11-11-2004 | 03:52 PM
ImportBuilder's Avatar
ImportBuilder
Default Turn signal noise
Let me try this again. I have a constant ticking noise coming from my dash. I sounds like my turn signal is on, all the time. It is a rapid ticking noise, like when your signal bulb is out and needs to be replaced. I checked all the light bulbs and they are fine. I checked the fuses and they are fine. I changed the turn signal relay and it has not changed. Someone told me it might be my "Turn signal cam gear" in the sterring column. He said the cam and spring might be out of sync. He also said I needed to replace the turn siganle arm and switch. HELP the noise is driving me crazy!!!! :loco:
