window help!!!!!!!!!
Old 10-21-2004 | 05:52 AM
Redlinerz's Avatar
Redlinerz
Okay I checked the fuses under the hood for the window and they are all good... then i took off the door panel and un-plugged and re-plugged the clips and played with the wires and everything seems to be fine and the window still don't move... and it doesn't go up slowly... it doesn't move at all. All the other windows work except the drivers side. Is there a way I can jump the motor to see if the window will go up? Or if I get a tester which wire do I check to see if the motor is getting power and see if it is good or not. I dont wanna buy a new motor if I don't have to. thanks
Old 10-21-2004 | 05:53 AM
Redlinerz's Avatar
Redlinerz
Oh yea and I tried to get it up manually and that chit doesn't budge at all.. how do you get it up manually?
Old 10-21-2004 | 09:46 AM
strykernyc's Avatar
strykernyc
what yr accord is this? if when u press the button to go up or down and u dont hear any noise at all, then the motor is most likely completely dead. in my case the cable snap so i can hear the motor but still with motor dead or cable broke u need a entire complete motor kit which u can buy n autozone with lifetime warranty
Old 10-23-2004 | 10:43 AM
sherwood's Avatar
sherwood
I missed Sean
prolly the switch, mine was f***ed up and i just flipped the switch around so the contacts made, well, contact
Old 10-24-2004 | 11:47 AM
Redlinerz's Avatar
Redlinerz
wha u mean flip the switch around? also is there a way that i can juss send power directly to the motor ato see if it goes up? and which wire would i send the power to? I juss dont wanna buy a motor if i dont have to thanks
