ABS Problems
Old 05-29-2004 | 07:44 PM
fino22's Avatar
fino22
Default ABS Problems
I think I have a speed sensor out on my 93 accords ABS system. I want to replace but for now can I just remove a fuse or the ABS motor to prevent it from working all the time. The ABS light was on for a while and it just plain out didn't work but after unhooking my battery to do some other stuff I think it reset and made the ABS think its ok but since the speed sensor is out it keeps on trying to activate the ABS system. Will removing the ABS motor just prevent it from working all together for now or will it screw something else up?
Old 05-30-2004 | 01:21 PM
mohamed_ibrah's Avatar
mohamed_ibrah
Tech in Training
When you're ABS light comes on, it will deactivate your ABS system based on the computer sensing something is wrong. I would have just left it with the light on instead of trying to reset as you did. If you don't want your ABS working, disconnect the wheel speed sensor at the location where it's bad, tape off the ends (to prevent crude from getting into the connection) and try to move it out of the way so the wiring harness doesn't get caught on something and rip out as you are driving. Realize though your light will be on. I don't know though if I would want to pull the ABS relay in the fuse box, in case that relay helps keep the actuator energizes so that some of the ports are open so brake fluid flows through them.
Do you know which sensor is bad (i mean which wheel)? What I've done before is sprayed brake cleaner on the teeth to help clean it out, so that the sensor can better read the teeth rpms, why don't you try that?
emry5treasure
2
04-08-2004 07:34 AM
1Greyteg
8
04-01-2004 09:17 PM
jzhuang
Accord
03-16-2003 06:24 AM
Vegeeta
Accord
5
08-29-2002 09:03 AM
Quick Reply: ABS Problems
