Suspension Help
Old 05-05-2004 | 06:09 PM
szemattaz's Avatar
szemattaz
Default Suspension Help
I have a 2000 Accord Coupe...and I just bought some Ground Control coilovers and i need some opinions.
What type of shocks would work best, yet give a smooth ride?
Are Ground Controls any good?
Will I need and front and rear camber kit and whats a good reasonable price brand?
Thanks for the advise and help
I just don't want to waste money and time on BS, when I can do it right from the start.....
Old 05-05-2004 | 07:13 PM
Intrepid241's Avatar
Intrepid241
The best advice I can give...is to use the SEARCH function. This topic has been beaten to the ground with a stick! hehe. All the info you need can be found with the search.
Old 05-05-2004 | 07:25 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I prefer straight springs like H&R or Eibach's over the GC w/ Eibach's but they should be ok.
I'd use Koni Yellows [www.shox.com] (sports) I recommend an Eibach rear camber kit[www.tirerack.com], the front will be fine.
And as other's have said look for suspension info via search.
Old 05-05-2004 | 08:29 PM
IamNemo's Avatar
IamNemo
You know me...
:werd:
Old 05-06-2004 | 12:16 AM
accord_coupe01's Avatar
accord_coupe01
I know this isn't the for sale forum but I'm trying to help him out. I have a set of Koni yellows neuspeed edition for sale I used them for less than a month. After you do a search you'll come to find out that they are considered as one of the best. Shox.com sells them for "$644 free shipping." There is nothing wrong with them I just want to switch to a coilover system and I need to sell them soon. How about $460 shipped. PM me if interested.
Old 05-06-2004 | 03:56 AM
skabone69's Avatar
skabone69
Konis
no(I would recommend either springs or a full coilover setup.)
only if you drop past 1.5in in the front and rear.
Old 05-06-2004 | 09:18 AM
polakatl's Avatar
polakatl
someone needs to sticky that suspension faq that was posted a little while ago. It sees like every other day we get the same suspension question. Spring shock or coilover. GC or regular. Eibach or H&R. blah blah blah
Old 05-07-2004 | 04:05 AM
syclone's Avatar
syclone
ground control with koni's will be the best setup... if you buy a complete kit from ground control, they use koni's as well..
Old 05-07-2004 | 10:35 AM
Nikon44's Avatar
Nikon44
If you have already bought the ground controls you have to check to see what shocks they are capable working with. I know that there are at least 2 maybe 3 different ground control setups for the accords. Ground controls a have different setup for Koni Yellow shocks and you have to make sure you get that setup if you run koni's. Right now I am running Neuspeed Race with Koni yellows and Ingalls Cambers. I will be switching to Ground Control Coils soon as I get the time to install them. Like the rest of the people here have said do a little research on this forum with the search or on the internet and you will find out everything that you need to know.
Sean
Old 05-07-2004 | 05:29 PM
Intrepid241
:werd:
Quick Reply: Suspension Help
