Warning to all AEM Bypass valve owners!!!
Older Honda Fanatic
sounds like that guy is an author... he wrote that with so much detail.
the problem a few years ago was with the foam getting injected into the throttle body... this new issue is with the rubber flaps.
Everyone is right though... put the car in neutral.
the lone outdoorsman
Accord Forum Moderator
Id turn the car off instead of putting itinto neutral, and revving the hell out of the motor. I'd just turn the key off one click. Yeah you loose power steering & power brakes, but the car will still be controllable.
Bottom line, the Bypass valve is faily useless unless you like driving through lakes; it even sucks in some hot, less filtered air from the engine bay. For all the trouble & risks, its really only a "feel-good" mod.
Older Honda Fanatic
Well, drop it in neutral and then shut the motor off quick... you can do some damage if you cut the ignition while the car is moving and in drive.
Now Popping a car at WOT into Neutral; that can cause some damage; rev limiter or not.
forstarters1717
10
08-23-2003 10:44 AM
