How tight for wheel bolts?
Originally posted by ride_out
I use an impact with a torque stick. its just as good. but i do the work MYSELF.
only me and one other persone works on my car.
Originally posted by LX4CYL
yeah, as long it's set to the right torque it's all good. I jsut don't trust anyone else to tighten the lugs with an impact wrecnh, so I make 'em break out the torque wrench!
Well, after I took my car to this one back woods shop to have new rotors put on they fawke dit up and my wheel fell off, I said only ME and this guy in chattanooga will ever touch my car.
:werd: hopefully all suspension work, brake work, and oil changes will be done by me. Alignments and other work I can't do in my garage will either be done at this kickass Honda dealer back home, or at the performance shop that charges more to mount+balance 18" tires mainly because they don't thrown your expensive rims around like they do at NTB or at Discount Tire Co.
So I got my winter tires put on yesterday...
If the air wrench has a pressure regulator on it, can this be ok when tightening the bolts to 80 lbs/ft2?
I told the guy the pressure should be at 80, but he said that it might be too loose. He normally sets it at 100. If the bolts were tightened to 100, might this cause faster damage to the rotors?
The pressure was adjusted to 80 anyway, but now i'm left with this paranoid feeling... I don't exactly want a wheel flying off when I'm on the highway... Can anyone help?
Thanks!
Thanks!
Thanks!
Thanks!
