Pound for pund dollar for dollar is it just as expencive to build a 12 sec hatch or..
Old 10-01-2003 | 03:50 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally posted by lt1fiero
ya umm no way im dumping 10k into my hatch cant do it im just gonna mess around with the suspention and motor swap and some good ol' super sticky tires same me a butt load of money and im not realy into hondas for show cars.so yeah if its gonna cost 10k might as well get a croch rocket
get a blower for your lt1. That should be good for some 12s :thumbup:
Old 10-01-2003 | 05:41 PM
Dimi's Avatar
Dimi
I doubt you even need a blower to get an LT1 powered Fiero into 12s...mild mods like headers, exhaust, intake manifold, ignition, and some slicks can clearly place you in 12s.
Old 10-01-2003 | 06:03 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Originally posted by Kai
I never considered the H22A swap a peice of cake.
I would consider it easy. I dropped the H22 in my 5G Civic coupe with no problems. With the Hasport mount kit its a bolt-in affair.
It's heavier so maybe that makes it difficult for some but if you do it properly by putting the car on a lift then roll the motor underneath it on a cart.... lower the lift to drop the car on top of the motor and ...... BAM!!!... an H22 samich..... yum:yumyum:
A built H will stomp all over a built B... let me guess... someone will scream yeah in a straight line, what about OVERSTEAR? Well, with a good stiff suspension you will be fine. Progress Auto makes springs with a spring rate specific to the H-series in the civic. Some good shocks, strut tower support, camber, etc. and you will be fine. Move your battery to the trunk as I did and get a cf hood and you cut a lot of weight from the get go. Really, handling shouldn't be seen as a problem.
And it definitely will not cost $10k to build if you are building it yourself. My complete motor, tranny, manifolds, downpipe, axles, hasport mounts, ecu, etc...everything you need was $3014 shipped to my door. Take that from the $10k and you have $7k left to build up the motor.... more than enough for an all motor bad ass build up.:thumbup:
Old 10-01-2003 | 06:07 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
I think they are all yelling understeer.
Old 10-01-2003 | 06:23 PM
h22avid's Avatar
h22avid
I was thinking understeer but apparently typed oversteer in my haist to post. I think it was because I was recalling this other post where a guy said he actually had a desirable oversteer after his suspension mods.
Thanks for the correction though:bowdown: I need to lay off the :bandito: :naughty:
Old 10-01-2003 | 11:08 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
so let me get this straight: a built "H" will stomp a built "B"...and a built "B" will stomp a built "D"...so that means a built "H" will.....awwww, crap. i'm screwed!!!
Old 10-03-2003 | 05:11 AM
h22avid's Avatar
h22avid
LOL:fawk: :thumbup:
Old 10-06-2003 | 12:08 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
It doesnt take that much to get into the 12's. Geez you people need to get out more often. h:
Yeah, my friend has a boosted D15B in his 5th gen CX runs low 13's. He's a few minor steps away from 12's.
Old 10-06-2003 | 10:19 AM
yellow civic ex
my god!! what does he have??? is the engine built up running a brapload of boost or something??? or slicks?? he has to have something besides just a boosted d15
Old 10-06-2003 | 11:23 AM
Cashis EG8's Avatar
Cashis EG8
Chech here: http://honda-tech.com/zerothread?id=420823
the only upgrades are fmu 12:1 and a walbro 255lph HP intank fuel pump
He ran between 10-12psi
