depo fogs
Old 09-13-2003 | 01:08 PM
rydnby 4's Avatar
rydnby 4
Default depo fogs
i just put in oem fogs, got through the wiring...and the damn things wont turn on
the switch lights up and i can hear the relay clicking when i turn them on...but no light beam...can anyone think of anything that might be wrong?...i figured it must be between the relay and the lights themselves (yah, i checked the bulbs)...is it possible to directly test them to see if its the lights themselves that are whack or my wiring job??...thanks for any help
Old 09-13-2003 | 01:20 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
have you tried to turn the headlights on and see if that allows the fogs to work?
they are dependant upon at least the parking lights being on too.
Old 09-13-2003 | 01:41 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
:werd: Also check ur grounds.
Old 09-13-2003 | 01:42 PM
rydnby 4's Avatar
rydnby 4
yup, headlights on, car on...no light beam
Old 09-13-2003 | 01:58 PM
rydnby 4's Avatar
rydnby 4
pretty sure grounds are all set, i double checked them and moved them around just to make sure...but the switch is getting power, and so is the relay...but the lights themselves are not
Old 09-13-2003 | 02:14 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
have a multimeter? go around and find wehere you lose power at
did you pop the fuse?
Old 09-13-2003 | 02:35 PM
rydnby 4's Avatar
rydnby 4
i dont think i have a multimeter here
the fuse is fine...this thing has me hella-confused...it seems rather unlikely that both fogs would be disfunctional, so i musta done something wrong...just dont know what
Old 09-13-2003 | 05:20 PM
Mx6GT91's Avatar
Mx6GT91
Do they have bulbs:squint:
Is there more then one way to have the wireing on the switch?? If there is then switch them around, I just hope that you dont blow a fuse
Old 09-13-2003 | 06:33 PM
rydnby 4's Avatar
rydnby 4
ha, yeah...they definitely do have bulbs, i wanted to make sure of that before i posted so that i didnt get ripped too hard...
the only thing left that i can think of is maybe the relay is bad?...it "clicks" when i hit tha switch, is this normal?...can these be found at any auto parts store or radioshack?
Old 09-13-2003 | 06:55 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
make sure you pluged the orange/brown plug into the right slot under the dash
