swap question
D16Z6... hmm, that's what I have. I think the stock WHP is around 103. I've heard of people having good luck running 5-8 PSI on all stock internals and it lasts. What matters most when running unmodified is your fuel management settings. Jkan will tell you all about it...
Drive it like it's a Taco
ok, was searching the web, and found the complete b18c1
for 2800.
then i found a h22a complete for 1950.
Engine Code: H22A (Complete!)
Year: 92-01
Valve train: DOHC, VTEC, 16 Valves
Transmission:Hydraulic
Displacement:2157cc
Horsepower:200 @ 6800rpm
Torque:161 lb-ft @ 5500rpm
Compression:10.6:1
Redline: 7200rpm
Engine Code:B18C (GSR)
Year:94-01
Transmission: Hydraulic
Displacement:1797cc
Horsepower:178 @ 7600rpm
Torque:128 lb-ft @ 6200rpm
Compression:10.0:1
Redline: 8200rpm
isn't the h22a a better engine? or am i missing a key here?
for 2800.
Year: 92-01
Displacement:2157cc
Compression:10.6:1
Redline: 7200rpm
Year:94-01
Displacement:1797cc
Compression:10.0:1
Redline: 8200rpm
H22A costs a lot to install do to custom fab work.
Look into a B18B, non vtec, cheap, amazing for turbo and you'll have more torque in the long run the a vtec engine.
SOLD THE ALLUM. WING!!!!
IMO, i would not get a b16a for the severe lack of torque. I rode in my friends hatchback that has a b16a engine swap. Absolutely no low end power. then again, if you put some nitrous in that, it would be amazing. Nitrous would give it some of that missing low end torque.
A swap is expensive. A turbo setup for your car is not as expensive and will yield more whp and less of a headache. If you're determined to swap, build the motor while it's out of the car, that way you have something to look forward to when you do swap it in.
so what your saying is put money into the stock dx motor and with enough work it should be decent until motor dies, then swap? im new (only 16) and would like a car that looks nice (all jdm) and is respectably fast, not ungodly fast
