timing belt question
Old 08-26-2003 | 12:30 PM
spooncivicb16b's Avatar
spooncivicb16b
Default timing belt question
how do i loosen the timing belt tensioner?i need to know how to get to it please if you can post pics
Old 08-26-2003 | 02:34 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
on the timing belt cover there should be a rubber plug. Unplug it and shove a 14mm socket through there and loosen the tensioner. Then push in on the belt to create slack, then retighten tensioner.
Old 08-26-2003 | 07:01 PM
spooncivicb16b
how do you tighten it?
Old 08-27-2003 | 03:54 AM
SpeedRacerEX-R
just loosen the tensioner and it will tighten it self. Be sure to retighten the bolt.
Old 08-27-2003 | 01:56 PM
spooncivicb16b
do i retighten it before or after im done and it tightens its self correct? is it on a spring or something? sorry if this all sounds stupid. also is it under the motor mount?
Old 08-27-2003 | 07:21 PM
oneslodx's Avatar
oneslodx
its on a spring, loosen the tensioner and spin the crank a few times, make sure you spin it the way its supposed to spin, i honestly cant remember but i spun it the wrong way after changin my timing belt, u run into all kinda timing problems. but just loosen spin the crank to let it self tension and tighten back down.
hopefully somone else can help u out on the correct direction to spin it
Old 08-27-2003 | 08:15 PM
dantastic's Avatar
dantastic
cx power!
u spin the crank counter clockwise (the way it usually rotates) when u retension the belt. to tension t-belt:
- loosen tensioner bolt
- turn the crank counter clockwise 3 teeth
- retighten tensioner bolt.
thats it. just changed the t-belt and water pump on my sucker. works like a charm
Old 08-27-2003 | 08:22 PM
spooncivicb16b
where is the bolt? and what do you mean by 3 teeth?
Old 08-27-2003 | 11:14 PM
spooncivicb16b
its this thing right?
File Type: bmp
Old 08-28-2003 | 11:28 AM
dantastic's Avatar
dantastic
cx power!
see that little plug/cover thingy on the cover, just to the right and below the engine mount. thats where the tensioner bolt is. i coulndt see the attached pic for some reason
