just got angel eyes, moisture problem
Hi, i was wondering if anyone here with aftermarket headlights has had a problem with moisture forming on the inside of the lamp. I have a 1995 Civic and bought the black molding angeleyes off of the internet. They look excellent, but i just washed my car and they got very foggy. I know this is a common problem, but has anyone found a way to fix it well? My thoughts were getting all the moisture already in the assembly out with a hairdryer, and then applying silicone along the perimeter of the case. You'd think they would seal them a little bit better! Well if anyone has any tips, I would really appreciate it. Why can't an upgrade go off without a hitch just once??? lol Thanks
Adam
Adam
Usually aftermarket headlights will fog up after a while because they are poorly sealed. That's why most of us opt for OEM headlights. You can put your headlights in the oven (low temperature and for a small amount of time only) so you melt the existing seal and seperate the lens. Reapply your own sealant and then reseal them :thumbup:
Also had that problem
i used the aquarium sealant and it worked. I used the aquarium sealant because aquarium sealant does not shrink in heat. I got it in Home Depot for like $4.95 and still it does not moist anymore.
thanks for the tips guys, i guess my question would be this. i know people do it all the time, but is it neccesary to use the oven/heatgun to get rid of the old sealent completely? or is it ok just make sure that that a put a nice thick seal on top of that all around the edges, because for the most part the seal is ok, but obviously there are some gaps that need taken care of. So Sealant on top of sealant ok? thanks
Aftermarket stuff sucks? *sigh* I guess I should have left those perfectly warped 10" factory front brakes on, and never installed the 13" Brembos I just bought.
Stupid me. I'll remember your words of wisdom next time!!!
Thanks OC!!!
P.S. The red 4 piston calipers look ALMOST as good as those rusted single pot. WHAT WAS I THINKING!?!?!?
Thanks OC!!!
Thanks OC!!!
Thanks OC!!!
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
