head gasket
Old 08-16-2003 | 11:39 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default head gasket
so, ya, I asked this question a long time ago and wanted to get another set of opinions cause I'm about to do it.
I'm going turbo in the next week and I'm going to be taking the head off just to check everything out before I throw boost on. I'll be replacing the head gasket at that time and wanted to get some REAL WORLD EXPERIENCE opinions on which head gasket I should get. I don't want any "well, I heard that you can spend $500 on some head gasket that God himself forged, but I don't know if it does any good". I need some ideas on what to get.
Last time I posted this OEM was the answer. Is that what I should run? I don't want to raise/lower compression with the gasket, just seal up the head to the block.
Thanks in advance.
Old 08-16-2003 | 12:57 PM
junglesnake's Avatar
junglesnake
Copper gaskets are known to leak.
Old 08-16-2003 | 01:05 PM
96cpe's Avatar
96cpe
i hear the inlinepro's work good.
Old 08-16-2003 | 01:15 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
well, i don't really know anything, but i hear OEM is pretty good. but that's just my opinion. :dunno:
Old 08-16-2003 | 01:30 PM
New93Civ's Avatar
New93Civ
My buddy used an HKS gasket and it has help though 15 pounds of boost no problem
Old 08-16-2003 | 02:14 PM
fook's Avatar
fook
Boosted D Series
true but ive been told if you can get one sealed its your best bet.
Old 08-16-2003 | 09:07 PM
DSC's Avatar
DSC
Long way from home
www.cometic.com
Old 08-17-2003 | 08:43 AM
ManTiS's Avatar
ManTiS
NinJA
Seriously, since you don't want to raise or lower compression; use an OEM gasket. I hope you have ARP head studs though.
Old 08-17-2003 | 08:59 AM
westcoaststyle
I already run ARP head studs.
Ok, OEM it is. :thumbup:
Old 08-17-2003 | 09:00 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
you could get your head o ringed (i think that's the proper term)
they make an indentation in your head and block, and put a o ring gasket in place of the headgasket. my friend put a copper headgakset and blew that, but that was after he blew the stock headgasket.
you may wanna check on that...
Project EVA - The Track Package
Project EVA
