b16 swap ?
Old 07-14-2003, 09:14 PM
snatch
snatch's Avatar
Default b16 swap ?
hey im finishing up my swap and im puting in the axels at the moment and im having trouble with the driverside i keep getting a solid axel and i have seen somewhere on the net that there is a half shaft that is seperate from the axle im wondering if anyof you have done the swap it this half shaft/ axel combo is what i need cuz i cant seem to find a solid axel that fits right any input would be greatly appreciated thanks
zach
Old 07-14-2003, 09:25 PM
Kai
Rotorphile.
Kai's Avatar
Which axle/intermediate shaft combo are you trying to use?
Old 07-14-2003, 09:47 PM
snatch
snatch's Avatar
i tried buying a axel from a 99 si but it dosent fit so i dont know if it is a wrong part or what but i found these on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2544813736
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2544367643
im thinking those will work but i dont know
Old 07-15-2003, 05:58 AM
Redcivic
One of the original OG's
Redcivic's Avatar
What gen B16A do you have and what year car are you putting it into? the ones that came with it should fit if your putting it into a 5th gen which I'm assuming you are.
Old 07-15-2003, 06:35 AM
LilDragonTKD
La Cosa Nostra
LilDragonTKD's Avatar
Try an integra axel
Old 07-15-2003, 06:53 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
B series swaps require the use of a half shaft on the driver's side.
Old 07-15-2003, 09:53 AM
snatch
snatch's Avatar
its a first gen b16a into a 93 coupe i think it needs the half shaft, will that ebay one work? also what should i ask for when im ordering the dr. side axel, like what car is it from?
*no axels came with the swap
Old 07-15-2003, 10:20 AM
westcoaststyle
any b series axles will work, but if you're worried, just get the B16A axles & half shaft. :dunno:
It's pretty straight forward man.
Old 07-22-2003, 09:31 PM
Civic2Scooby
Civic2Scooby's Avatar
I used 95 gsr axels and intermediate shaft for my b16a into a 95 civic...they fit perfect and you know they are the right shaft with intermediate combination because they have a unique setup as opposed to all the other axles
Old 07-22-2003, 10:17 PM
snatch
snatch's Avatar
right on thanks!
