How to make a SOHC VTEC pull like a DOHC VTEC
Old 01-16-2004, 07:03 AM
  #121
Redcivic
One of the original OG's
Redcivic's Avatar
I've got your doodoo B16A right here . I'm so sick of this B18 is better than B16A crap. When I am done with my SOHC VX, I will be able to spank a Type-R just for starters. If you plan correctly and buy the right parts a SOHC VTEC can be just as fast a DOHC VTEC. Yes the DOHC motor will have a higher ceiling of power but that ceiling is very high so I doubt you will get that crazy with it. Look up all motor SOHC Honda's and you will see. I'm looking at about 200HP from my brand spanking newly built SOHC D16Z6. With the weight of my stripped VX I should be able run soem pretty goos times. I'm hoping for 13's for starters. Then I'll see about a different cam and some really serious valve train parts. I'm making my own gude head package. We'll see, this could blow up in my face but I've always wondered what a SOHC VTEC could really do.
Old 02-02-2004, 07:52 AM
  #122
thevtecnician
thevtecnician's Avatar
get some VTEC cams. check out skunk2. those cams can exploit the vtec in your sohc
Old 02-02-2004, 07:55 AM
  #123
alphaxxn
4500rpm hesitation
alphaxxn's Avatar
Jesus isnt this post like 3 years old?
Old 02-02-2004, 08:08 AM
  #124
oc_civic
mcc racing
oc_civic's Avatar
Old 02-03-2004, 07:50 PM
  #125
theguy387
theguy387's Avatar
port and polish my man. and it's not that expensive on single cams
Old 02-03-2004, 07:52 PM
  #126
qtiger
qtiger's Avatar
Right, because they have half the ports... :thinking:
Old 02-03-2004, 07:54 PM
  #127
veen
Seņor Member
veen's Avatar
Originally Posted by oc_civic
:chuckles: hey man, hes the VTECnician!
Old 02-04-2004, 08:01 PM
  #128
sspire
sspire's Avatar
IMO d motors are good and reliable and all but they have LONG gears and low stock power. b series have shorts ratios and have ALOT more potential for power, if i were you i would go DOHC. DOHC non-vtecs pull verrrrrrry nice, they will also plant you in your seat. BTW please dont turn into a NOS junkie if thats is the rout you are choosing to take.
Old 02-04-2004, 08:04 PM
  #129
sspire
sspire's Avatar
sorry, didnt look at the experation date
Old 03-02-2004, 10:47 AM
  #130
BCTUNED
ECU Tuning whore
BCTUNED's Avatar
ECU-wise we can help you make that SOHC pull like a DOHC. We've had a little DX beat even GSRs on the streets...all bolt-ons. Gas mileage sucked though....but the look on the guys faces when they saw the DX motor that beat their might DOHC VTECs was priceless
