Any suggestions appreciated!!!
Old 06-27-2003 | 04:48 PM
sleepisgood's Avatar
sleepisgood
Default Any suggestions appreciated!!!
hey guys
I have a 96 civic ex 2d, and I failed my emission test for state inspection
I got an error with the intake air temp sensor, and i have a sneaking suspicion that it's because the sensor is not plugged in :-P.
I have an iceman intake and there isnt anywhere i can plug the sensor in, so do you guys know any intakes on the market that do, so i can pass my test?
Any other suggestions(other than going to a junk yard and getting a factory intake...that'll be plan b) will always help
Thanks
Old 06-27-2003 | 04:58 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You need to remove the intake from the car, remove the filter from the intake, and drill the hole for the sensor. You will also need to go get a rubber grommet with the outer diameter of the hole you drilled and the inner diameter to where the sensor will fit snugly inside.
Clean out the intake as best you can before you reinstall it.
That's how you get the sensor in there correctly. I have no idea if that will allow you to pass your test....
HIH!
Old 06-27-2003 | 06:45 PM
sleepisgood
thanks for the info, btw do you know any good short rams that have that plug in? this iceman is crap and i'm thinkin of upgrading
Old 06-27-2003 | 06:50 PM
Slacker's Avatar
Slacker
AEM has the plug. Well I know the CAI does...
Old 06-27-2003 | 06:54 PM
CivicRacr's Avatar
CivicRacr
AEM short ram does have the hole for the sensor
Old 06-28-2003 | 02:23 PM
sleepisgood
thats where i was leaning, I just ordered it......i love buying new toys....:-)
