civic conversion problems!!! HELP....
Old 06-25-2003 | 10:13 AM
daniel_civic's Avatar
daniel_civic
Default civic conversion problems!!! HELP....
I have a D16A SOHC non-vtec engine, i bought a D15B SOHC VTEC engine. I used the 1.5 vtec head on my 1.6 block. At present i have no engine check lights,i had to install a few sensors to get the check light off. also i used the 1.5 vtec ECU and the entire wiring harness.At present the car is not responding as it should,the car does not have all the power.The vtec seems to be engauging but not as how it supposed be.When i disconnect the vtec solenoids the car is even more dead, and i dont know what to do...
ADVICE NEEDED....
Old 06-25-2003 | 10:27 AM
94civicEX's Avatar
94civicEX
I got worms.
I would have just swapped the D15B into it. You'll have more power with the D15B than the other.
99 Integra GSR
06 TSX
duck squad member #00003
Old 06-25-2003 | 12:43 PM
daniel_civic
thanks for the info, but why did you suggest that the d15b will have more power??
