engine turning = battery charging?
Old 06-22-2003 | 03:54 PM
Kai's Avatar
Kai
Rotorphile.
When you engage the clutch, the engine starts turning over and the alt is generating current... basically the car thinks its running like normal and fires right up.
When I do it, I let the clutch out and push the throttle in at the same time. If you get the timing right, the car smoothly cuts on and starts going under its own power.
Old 11-13-2003 | 09:16 AM
weshirecat's Avatar
weshirecat
hi there
I have a 87 crx hf and i'm getting the alternator light coming on sperratically while i'm driving.
any ideas?
Old 11-13-2003 | 09:20 AM
Kai's Avatar
Kai
Rotorphile.
Holy dead thread!
Maybe replace the alternator?
Take your car to a local Autozone or similar, they should be able to test it for free.
Old 11-13-2003 | 01:24 PM
toadolson's Avatar
toadolson
The One And Only!!!
Someone used the seach button first.
:bowdown: :bigok: :bigok:
Your belt might be slipping or the voltage regulator is going out. Autozone or checker test is your friend.
Old 11-13-2003 | 01:37 PM
Vividkid82's Avatar
Vividkid82
Originally posted by frank
hey thanks for the info. i can draw my own conclusions from your points, thus enabling critical thinking skills
hahahahaha
Old 11-13-2003 | 07:55 PM
Kestrel's Avatar
Kestrel
Push to shock!
I thought it was that the car can be run off the battery only without an alternator, just that you'll drain your battery after a while. I remember when I was in FSAE we used only batteries in our car with no alternator....
:dunno:
Old 11-15-2003 | 01:04 AM
frank's Avatar
frank
frank from canada
ahahahah i was like omg. who's this frank guy. this bastard stole my name. and then i was like oh thats me, like 5 months ago!
Old 11-15-2003 | 06:44 PM
Kai's Avatar
Kai
Rotorphile.
The battery would drain pretty quickly, but it would work just fine for a day or two. You can also run only off an alternator with no battery, but that is a very bad idea for cars that aren't designed for it. The ones that are have little capacitors (mini-batteries, if you will) to smoothen the power output of the alt.
