is it ok to do a swap if i never did it b4?
VTEC wiring is easy, the chassis is wired so from there you just tap, tap, tap. go to hybrid garage for details. The major thing is tools though. I have a full garage with about every tool imaginable so it was easier. Also change the clutch, timing belt, water pump, rear main seal, cam seal, crank shaft oil seal, on the other motor before you put it in. You will also need all your gaskets, retaining clips for the axles, spring pin for shift linkage etc. Get everything because the dealer parts places are not open late or on weekends. oh and get your fly wheel resurfaced.
