jdm B18C1 wiring help
Old 05-07-2003 | 03:09 AM
vtecfed's Avatar
vtecfed
RIP VTECFED
Default jdm B18C1 wiring help
So I've done all my homework on the transplant into my dx hb but, I can't find much info on wiring up the engine. Can anyone tell me or give some web sites.
Again I will be putting a 94-96 jdm B18C1 into a 93 dx hb
Old 05-07-2003 | 04:02 AM
92teg's Avatar
92teg
try here http://tech.hybridgarage.com/tech/5g...ex.html#B18EG6 :thumbup:
Old 05-07-2003 | 04:32 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly where I was going to go. :thumbup:
You might also try www.jdmfan.com
Old 05-07-2003 | 09:26 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Remember to use the US harness too.
Old 05-07-2003 | 09:38 AM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
And post pics when it's done...
Old 05-07-2003 | 07:34 PM
vtecfed's Avatar
vtecfed
RIP VTECFED
ok I've done some more investigating into this swap and read that the only plug that won't directly fit from USDM to JDM is the ecu plug because its backwards. Is this right.
Old 05-07-2003 | 07:54 PM
dantastic's Avatar
dantastic
cx power!
umm... if the motor doesnt have a usdm harness, you need to use your stock usdm engine harness, and run the 4 additional wires
Old 05-07-2003 | 09:05 PM
vtecfed's Avatar
vtecfed
RIP VTECFED
come on I know you guys have done this swap
Old 05-07-2003 | 10:24 PM
dantastic's Avatar
dantastic
cx power!
u dont need to mess with any of the wiring on the car itself, bsides adding the 4 wires. the usdm ecu plugs are the same as jdm, even the pin layouts are the same
Old 05-07-2003 | 10:54 PM
vtecfed's Avatar
vtecfed
RIP VTECFED
so why does it take people only 2 hours to put the engine in and 8 hours to wire it up?
