what is this noise while I'm driving
Old 06-28-2002 | 02:03 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by derf
what gets really sticky?? if you are talking about anything with brakes i really don't think its them like you said. I will have this squeeling when I'm driving in the morning, nite, on the highway, ANYWHERE> its there and won't go away.
have your wheel bearings checked out.
Old 06-28-2002 | 09:20 PM
derf's Avatar
derf
Spec5
any1 have a rough estimate of the cost of checking out the bearings? are they easy to replace?
Old 06-28-2002 | 09:58 PM
Fujiwara Takumi
It's my first day.
you can repack bearings yourself, but its not something I personally would do, because I dont know how.
ive heard quotes as high as $300 a pair, (front two wheels)
Old 06-28-2002 | 10:17 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Wow that's expensive. But my mom's old mini van had the same thing happen. There was no greese in the wheel bearing.
Old 06-28-2002 | 10:22 PM
Fujiwara Takumi
It's my first day.
nobody wants to do it cuz it's a mess.
the bearings themselves i think are like 50 bucks a wheel or something.
Old 06-29-2002 | 10:44 AM
rawkus's Avatar
rawkus
(oYo)
i once had a rock stuck between my rotor and that plate behind it and it squeeled really bad. just a thought.
Old 06-29-2002 | 12:21 PM
94sedanman's Avatar
94sedanman
someone else had had the same problem and it turned out to be his dust cover, he just bent it out of the way from the rotor and it stopped
Old 06-29-2002 | 07:40 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
sounds like your brake pad is wearing out. I had the same problem and i thought something was wrong with the axle. The noise was especially bad in reverse. Check your brake pads, and replace em. Resurface your rotors while you do too, it will make a big difference.
Old 06-29-2002 | 07:41 PM
derf's Avatar
derf
Spec5
thanks for the advice, its not the bearings according to my dad, and the brake pads are less than a month old. its neither... gotta go figure it out now
Old 06-30-2002 | 07:14 PM
crucial Si's Avatar
crucial Si
Banned
i think i figured out the problem...when i spin the tires while its jacked up they sound like the pads are rubbing the rotor...so im thinking its making the noise. i gotta check out my master brake cylinder tomorrow morning
Quick Reply: what is this noise while I'm driving
