my 5gen ex is running like crap. WTF is going on?
Old 06-28-2002 | 08:48 AM
crucial Si's Avatar
crucial Si
Banned
Originally posted by OneToughCivic
i'm just going to replace the plugs wires and cap/rotor. if that doesn't do it, then
thats alot of money that your going to waste if its something simple as a bad wire.
Old 06-28-2002 | 09:58 PM
OneToughCivic's Avatar
OneToughCivic
it all needs to be done anyways - regardless of wether or not it's the problem. i've put it off for a while
Old 06-28-2002 | 10:22 PM
Luis's Avatar
Luis
Civic1.6VTEC
make sure the plugs are gapped right. that happened to me, and it was because one of the plugs was almost closed.
Old 06-29-2002 | 07:43 AM
crucial Si's Avatar
crucial Si
Banned
Originally posted by Civic1.6VTEC
make sure the plugs are gapped right. that happened to me, and it ws because one of the plugs was almost closed.
i forgot about that..good idea. they are probably gap wrong :thumbup:
Old 06-29-2002 | 10:14 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
replacement engine, blowing black smoke...
my guess, you have a bad valve or two. Your head will need rebuilt most likely. Thats what it sounds like to me at least. have a compression check done
First, like you said, replace plugs and wires and dist cap, if you really don't notice a difference, keep them anyway, they should be replaced every so often anyway, it's regular mainanance. But, if you don't notice a pickup, and you're still running rich after those replacements, have a compression check done. You may either have a bad head (vavle bent/broken) or your head gastket is kaput, although i don't think that this is the problem.
I am not god, I am not a professional mechanic, take everythign you read anywhere on the net with a grain of salt.
Old 06-29-2002 | 06:47 PM
OneToughCivic
ManInCamo - i had a compression test done right after i had the motor swapped and i noticed it was blowing smoke. the compression was good on all 4 cylinders
so... WTF?
Old 06-30-2002 | 08:26 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If worst comes to worst, get the ***** over to my place in Mn and I'll throw one of my spare engines in. I'll do it cheap too!
Old 06-30-2002 | 09:57 PM
AzDrag's Avatar
AzDrag
Pull the plugs. The plugs say everything.
Old 07-01-2002 | 10:41 PM
OneToughCivic
i'm gonna pull the plugs tomorrow. i'll update j00's when i do it. wish me luck
Old 07-02-2002 | 08:50 AM
crucial Si's Avatar
crucial Si
Banned
haha...you have a bad wire...come to my shop and ill swap you a new engine..haha
HawtPants
04-23-2005 11:35 AM
Fujiwara Takumi
06-02-2003 03:02 PM
HatchVX
92+ Civic/EL & Del Sol
10
02-23-2003 06:48 AM
b's94accord
Accord
2
02-10-2003 07:46 AM
Turbo Teggin
09-11-2002 03:12 PM
Quick Reply: my 5gen ex is running like crap. WTF is going on?
