Eibach Sport Lines & Konni Yellows together?
Originally posted by igo4bmx
koni yellows are over 500 a set and the sportlines should be around 200
you could get a set of full coilovers for around that much money.
A coilover suspension is simply one that has the shock body located within the space inside the coil spring (as installed on the car). This is the best design possible because the shock is moving in the same plane as the spring, which ensures that it can most accurately control spring movement, plus it's usually the lightest.
Originally posted by Cross
Excuse me for my n00bishness. But what are coil overs. And I am too lazy to do a search
I had Sportlines with Koni Yellows. I thought it handled awsome until I got Ground Controls.
Ground Control > Sportline h:
Hounestly, Ground Controls are WAY better.
Originally posted by porschetr
coilovers are height adjustable springs.
add a little more and get yourself tein coilover kit...
check this link out
http://www.groupbuycenter.com/buy.aspx?id=9536
you might need to sign up.
you can get a set of TEIN ss coilovers for 92-00 civics for 850.
i would get those
i would get those
check this link out
i would get those
check this link out
i would get those
I would go GC based on the fact that you can recommend your desired spring rate :naughty:
Originally posted by 4-banging
what are the spring rates on those bishes?
