Ideas on horn install on Momo wheel
I know how to wire up the horn, but I don't feel comfortable in just tapping the wire and running it to the button.
I'm also tryin' to set it up so I don't see a wire running up to the steering wheel column. I've got an idea of using a brush and connecting to to the bottom of the hub. And then simply using the wire momo sodered to the hub as the positive wire, and grounding the horn to the hub. So all the wiring is able to turn like normal.
What have you guys done, and I'm open for more ideas.
what no one else has any ideas?
to get some converstion going
to see if someone has a better idea than i do
Yeah i need to figure this out too .. I have a 96 accord, and I had to cut the coil with the SRS and Horn wire, but I need to find a way of running the horn wire to something and get something to touch the bottom fo the hub so it makes contact with the area the horn wire is... plus on my momo wheel, the horn button only has one place for a wire..are there supposed to be two? I would think one hot, and one ground.
i keep hearing about using some parts from a CRX. i forgot what parts though h:
This right here is the best way to wire up the momo horn. i did it like this and it worked perfectly.
http://www.honda-tech.com/zerothread?id=273474
It's by a user named dnt94civic. he's on this board and the h-t.com
best solution yet.
best solution yet.
