burning smell--WTF?
Old 03-12-2003, 06:27 PM
jenkinsisme
jenkinsisme's Avatar
Originally posted by one2bseen
was that your car? i thought it was that truck the other day.what about a wire pulling too much power and burning?
I smelled it yesterday also, so I think it's my ride
Old 03-12-2003, 07:40 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
Sounds like it's leaking exhaust right up at the head. If you check the torque on the bolts there, I'm sure you'll find they're loose. When you're in the upper RPMs it will push the manifold away from the head, and cause a leak... I had the same problem, and know the smell you're talking about. Check it out, can't hurt to try.
Old 03-13-2003, 05:45 AM
jenkinsisme
ok, so what's the torque supposed to be so I can check it?
Old 03-13-2003, 12:49 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
23 ft/lbs
Old 03-13-2003, 01:03 PM
dantastic
cx power!
dantastic's Avatar
Location: berkeley, ca --> la, ca representin' tha 510&626
hmm... my accord used to smell when i drove it *really* hard, or over 100mph for extended periods... i just assumed it was normal
Old 03-14-2003, 12:37 AM
ASpec818
ASpec818's Avatar
i dunno my old motor did that in my 93 si. it had about 130,000 miles on it. now that i got a 99 gsr swap, it still smells like somethings burning sometimes when i mash the throttle. either its normal or dunno?
Old 03-14-2003, 10:49 AM
jenkinsisme
Originally posted by Bakeoff
23 ft/lbs
ok, so are you talking about the actual head bolts,or the bolts at the header? If you are talking about the head bolts, what is involved in doing this? I've never done it before.
Old 03-14-2003, 11:04 AM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
take off the heat sheild, I think it's 3-4 bolts, and thy're normally rusty. Then the bolts that actually connect the manifold to the head are the ones to check.
