need help switiching out headlight
Old 02-27-2003 | 07:12 AM
NewbieCivic's Avatar
NewbieCivic
Default need help switiching out headlight
i have projectors on my 92 - 95 civic ex..and i want to put back on my stock headlights...can someone give me a step by step detail on how to change from projectors back to stock headlights?
thx
Old 02-27-2003 | 08:29 AM
4-banging's Avatar
4-banging
never done it but I would think you just reverse the process :dunno"
Old 02-27-2003 | 09:33 AM
civic2k2grl's Avatar
civic2k2grl
ahhh whats so hard..if u can get um in then u should be able to get um out... just take off ur bumper and start unscrewing stuff...
Old 02-27-2003 | 09:43 AM
The Beav's Avatar
The Beav
i
my headlights on my 6th gen just bolt on, so your 5th gen is probably the same and the bulbs should match up unless you did some kinda conversion
Old 02-27-2003 | 09:51 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Easiest way is taking off the bumper. Should be 5-7 screws on the top, and 2-4 underneath the car. Once that is off everything else is self explanitory. Should be 3-4 bolts holding the headlights to the chassis.
Autocross Help Page
Old 02-27-2003 | 09:55 AM
The Beav's Avatar
The Beav
i
woah, civicsiracer, you never post anymore, good to see you around the board again
Old 02-27-2003 | 11:40 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
on 5th gen you actually have to take the front bumper off cause there's a beam just in front of the headlight that holds it in there. You can't take the beams off unless you remove the front bumper cause they're bolted to the front support beam.
It's those 2, one just under the corner, 2 on top and one on the inner side of the headlight. There's a cutout for it and you don't have to remove it all the way, just loosen it.
All the bolts are 10mm.
Old 02-27-2003 | 12:47 PM
CivicSiRacer
YYeah I have been Just picking on random posts though.
Autocross Help Page
Old 02-27-2003 | 12:50 PM
The Beav's Avatar
The Beav
i
yeah, but you used to be a big player in the board, and i never see you post anymore, what ever happened to your idea for creating shirts for the civic board members?
Old 02-27-2003 | 03:05 PM
NewbieCivic
ok...i got all that down..now what do i do with all the wiring? what do i unplug and what do i plug back in?
