Engine running like crap
Old 02-22-2003 | 08:25 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default Engine running like crap
Today i was gonna to get some stuff and after all the hard rain, there was one spot that was flooded. I slowed down to about 15 and only about 1/2 throtle, then a truck passed me on my passenger side then right after he passed me my engine bogged down like anything, as in i had it in first and it wasn't moving much. but after about a minute it went back to semi normal, but now i have a loud clicking or knocking on the Valve train on the 1st cylinder. The engine isn't running with as much pull as it did b4 the water hit it. What could it be?? BTW it a D15B8 converted to a D15B7 (swaped the CX head with a DX one) Also it was smoking b4 (due to bad valve guides but after my the water thing it smoked even worse now and it smells like oil. Its light blue smoke.
Thank for the help
Patrick
Old 02-22-2003 | 08:33 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Sounds like your burning oil to me. Knocking? Maybe the valves are hitting. Could be timing?
Old 02-22-2003 | 08:48 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default Re: Engine running like crap
Thank for the help
Patrick
I have just a little experience with this h:
You may have done a lot of damage, but then again, you may not have done much at all. Water inside your motor is a very bad thing. If you're expereincing a loss of power and it's smoking a lot, you may have sucked water into your combustion chamber and cracked a piston or something. It's very possible considering all of your symptoms. Have you taken your #1 plug out and tried to look at your piston? That's what I would do. And I'd change my oil too. It's really hard to diagnose considering all of the possiblites with hydrolocking....
Old 02-22-2003 | 09:10 PM
ManTiS's Avatar
ManTiS
NinJA
blue smoke tends to be burning coolant
Old 02-22-2003 | 09:45 PM
dantastic's Avatar
dantastic
cx power!
white smoke = burning water or coolent
bluesmoke = oil
Old 02-22-2003 | 09:49 PM
Brad's Avatar
Brad
wooo nascar!
uhm.. blue smoke = burning oil. i dont think coolant burns blue.
Old 02-22-2003 | 09:57 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
:doh:
Know your roll Beavis.
Old 02-22-2003 | 11:36 PM
HatchVX's Avatar
HatchVX
so why would me engine be buring more oil than it was b4??
Old 02-23-2003 | 06:29 AM
westcoaststyle
Did you not read what I posted? :doh:
Old 02-23-2003 | 06:33 AM
The G2 Racer
Want Boost!
Listen to Josh he knows about hydrolocking :fawk:
Hope you get it sorted out man.
