b16a2 in 92 dx
Old 02-18-2003 | 10:56 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by fish
if my memory serves me correct all of those SI parts can pretty much come from any b-series motor.
Most yes, but not all (ie ECU). You never know how much someone knows about Bseries stuff so I kept it simple.
Old 02-18-2003 | 01:53 PM
MoFo's Avatar
MoFo
Baddest mf'er...ever.
Si, will work, but you don't NEED to use only parts from an EG si
Integra axles work fine.
I have a GSR wiring harness
LS throttle body, and linkage, and brackets.
A salvage yard is going to become your best friend.
One thing I'm not too sure about, he has an OBD II engine, does he have to use OBD II sensors, or will a OBD I ECU overide all that?
Old 02-18-2003 | 04:17 PM
westcoaststyle
OBD1 ECU will not be fed the wiring for the OBD2 sensors since his ECU harness is OBD1. He'll just need to add the additional sensors that the OBD1 ecu needs from the Bseries upgrade.
Old 02-18-2003 | 05:43 PM
Redcivic's Avatar
Redcivic
One of the original OG's
OBD -1 OBDII nightmare. Good luck.
