short shifter
Old 02-18-2003 | 08:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by AlmostSiR
do bushings make that much of a difference? where would I get them???
Nopi: http://www.nopionline.com/index.cfm?...20Kit&vaffid=0
Options: http://www.optauto.com/webstore/prod...ept=28&last=28 (you'd have to call them cause they don't have them on the site right now)
I'm sure that more places carry them too...
Old 02-18-2003 | 10:13 PM
ret's Avatar
ret
im dying inside
i have a dual bend skunk2 ss, Im guessing it is like the gsr ss's?
Old 02-19-2003 | 10:41 AM
dubss's Avatar
dubss
i got a B&M...need bushings.
Old 02-19-2003 | 11:37 AM
spooncivicb16b's Avatar
spooncivicb16b
i have the skunk 2 dual bend with bushings it feels great ant the shifts ar easy and precise.
Old 02-19-2003 | 09:18 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Originally posted by Outxider
it a tad shorter throw then the civic shifter and the bends puts it closer to the driver.
late
but i've heard that the gsr ss will not fit on civics without modifications... is that true?
Old 02-19-2003 | 09:25 PM
Outxider's Avatar
Outxider
X-Motoring
okay, here it is, the truth, a AFTERMARKET gsr short shifter will fit cuz they r built with a narrow end to connect to the linkage. on the other hand a STOCK gsr shifter will not fit a civic unless u grind the end down bout 1/4 inch or so to fit the d-series linkage, cuz the b-series linkage is more wider. after u grind it down, pull ur bearings out of ur stock civic shifter and put them bakk into the integra one. if ur confused, ask away.
late
Old 02-21-2003 | 12:30 PM
maskedSONY's Avatar
maskedSONY
bushings are useful. with my cheap ass short shifter, when i place it in gear, i can wiggle the shifter to the right and left while its in gear. bushings eliminate that extra play in the shifter mechanism and provide more accuratly defined gates for shifting.
Old 02-22-2003 | 11:09 PM
dantastic's Avatar
dantastic
cx power!
Originally posted by dantastic
i bought some generic gsr ss on ebay. $20 and my shifts are hella short... just a bit notchy. now for some bushings....
oh yea.... i have a b16a no mod necessary
