Swapping EG Gauge Clusters
Old 02-03-2003 | 04:51 PM
RedRexDX's Avatar
RedRexDX
Stupid Hurts
Default Swapping EG Gauge Clusters
Im swapping from the DX cluster to the Si cluster in my 92 HB. Is there any way to change the mileage to match? ive only got 47K miles on my motor and id love for my new cluster to reflect that. there doesnt seem to be a hole for a speedo cable, so how are speed and rpm signals tranferred? electrically? and will i be able to use the tachometer without any additional wiring??
Old 02-03-2003 | 05:11 PM
Tirod's Avatar
Tirod
besides the mileage.. i believe everything else is plug and play
Old 02-03-2003 | 05:21 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Everything is plug and play as long as you are swapping a manual for manual or automatic for automatic cluster. You can use your existing speedometer on the new cluster. It comes off with a few screws in the back :thumbup:
Old 02-03-2003 | 07:05 PM
dantastic's Avatar
dantastic
cx power!
thats wat i did..... my si cluster had 160kmi, while i really only had 130kmi
Old 02-03-2003 | 07:06 PM
RedRexDX's Avatar
RedRexDX
Stupid Hurts
awesome! uhh, will anything fall out if i take the back apart?
Old 02-03-2003 | 07:09 PM
dantastic's Avatar
dantastic
cx power!
be REALLY careful when working with it. the speedo comes out with 3 or 4 screws out of the back. theyre pretty obvious. but nothin should fall out
Old 02-03-2003 | 07:51 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Uh. A Manual cluster will work in an auto car you jsut don't have the shift selector lights. I have a manual Si cluster in my auto DX (the auto will change in time).
There's three or four screws in the back holding the speedo in the cluster, remove them and it shall drop out.
Old 02-03-2003 | 07:56 PM
Cashis EG8's Avatar
Cashis EG8
I know it will work, but the SRS plug (that also contains the auto indicator wires) won't fit so it's technically not plug and play
I have an SI on my auto DX also.
Old 02-03-2003 | 08:07 PM
The G2 Racer
Want Boost!
I don't have air bags
Old 02-03-2003 | 08:13 PM
RedRexDX's Avatar
RedRexDX
Stupid Hurts
I'm going to take pictures and post in the DIY forum.
