Brakes tech question
Old 06-20-2002 | 08:04 AM
rajc007's Avatar
rajc007
Default Brakes tech question
I recently got my brake pads replaced by the dealer and ever since it seems like i have to jam down on the brake pedal to stop. took it back and they said that there's a leak in the master cylinder and it has to be replaced.....$200 for the part and $100 for labor.
Does this sound like the correct fix for my problem or am i getting screwed? i'm not too familiar with the braking system.
Old 06-20-2002 | 08:28 AM
DakarM's Avatar
DakarM
Default Re: Brakes tech question
did they bleed te brakes when they changed the pads?
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old 06-20-2002 | 08:46 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default Re: Re: Brakes tech question
That's exactly what I was going to ask. Bleeding the brakes - $5 for brake fluid.
Autocross Help Page
Old 06-20-2002 | 08:47 AM
rajc007's Avatar
rajc007
not sure, but i will ask when i go back there tomorrow. i have driven about 3000 miles after they installed the pads......
Old 06-20-2002 | 09:03 AM
rajc007's Avatar
rajc007
thanx for the replies, it seems like those bastards always try to rip me off everytime i bring my car in....
Old 06-20-2002 | 11:24 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if it wasn't a problem before you went in, and it was after, then they didn't properly bleed 'em.
Old 06-20-2002 | 12:41 PM
derf's Avatar
derf
Spec5
if you have a garage i personally suggest in investing in some socket and wrenches, a hydraulic lift..... you can change the oil yourself, even the brakes. on a civic they are extremely easy to do. and we are always here to help you took me 40 minutes to change mine.... but i think one of the calipers has gone bad
Old 06-21-2002 | 04:40 AM
Guest
Guest
Posts: n/a
The Honda dealer told me my master cylinder wa sgoing bad about 80,000 miles ago. I had some slop in the pedal but then i changed the rear pads and the slop disappeared. So, they were just trying to get to me to buy a new master cylinder. Bastards
themonsteraria
92+ Civic/EL & Del Sol
3
08-21-2009 03:36 PM
NoRiCeHeRe
3
07-11-2003 12:32 PM
coil222
3
07-15-2002 05:24 PM
95acurals
4
07-12-2002 01:46 PM
Quick Reply: Brakes tech question
