camber questionnare
Old 01-28-2003 | 09:19 AM
4-banging's Avatar
4-banging
Default camber questionnare
people with GC's and on a 96+ civic rolling on 17" wheels, what camber kit are you currently running?
ingalls
skunk2
progress
other
Old 01-28-2003 | 10:22 AM
cobbcustomz's Avatar
cobbcustomz
Ingalls Front and rear
Old 01-28-2003 | 11:14 AM
4-banging's Avatar
4-banging
with this set-up, how off was your camber? (b-4 camber kit)
Old 01-28-2003 | 06:29 PM
cobbcustomz
ehhh not really sure, I installed the Coilovers and camber kit at the same time and adjusted camber myself to get it somewhat straight before i brought it to a shop. I had rubbing issues with the rear of the car so i still have negative camber in the back as we speak.
Old 01-28-2003 | 08:46 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I'm getting the Skunk2 front camber kit and doing the rear washer trick
Autocross Help Page
Old 01-28-2003 | 09:51 PM
ccivic97's Avatar
ccivic97
i have the ingalls front and rear camber kit w/17's, its the best kit i've seen so far, not sure how much my camber was off but to solve the rubbing in the back just get a dremel and hack off the inside of the fender and on the front cut out the black plastic and roll up the screw tabs. should eliminate most rubbing but with good camber your always gonna rub a little.
Old 01-29-2003 | 08:02 AM
4-banging's Avatar
4-banging
thats what I plan for the rear as well, 1/8" shims should work.
Why the Skunk2's over the other brands?
are you using the GC's? what does the rear kit consist of?
Old 01-29-2003 | 09:24 AM
CivicSiRacer
It was a hard decision, but between the Progress Group and Skunk2 they have they are on alot more race cars than Ingalls or other brands. Taz Harvey and his partner if I remember right run Skunk2 front camber kits.
Autocross Help Page
Old 01-29-2003 | 09:32 AM
ManTiS's Avatar
ManTiS
NinJA
The Skunk2 is also red ... or it used to be
Old 01-29-2003 | 09:31 PM
ryewdedyet's Avatar
ryewdedyet
I use the SPC (Specialty Product Company) control arm camber kit. In my opinion its better that Ingalls 'cause its easier to adjust for camber and caster. I also use an SPC rear camber kit. The front is good all the way up to 3.5 deg. The rear is good all thru 5 deg.
There is slight fault with the front kit though. If you lower your car more that 3 inches, the camber adjusting screw will touch the upper pillow shock mount. You can easily solve this by buying a smaller screw or grind off a little of the upper shock mount. On a 96-00 Honda Civic, you'll see a factory notch already made on the rear pillow shock mounts. Other than that the kit is very user friendly.
