Indaglo gauge help needed!
does anybody know what wire (i.e. color, distinctive marking) i need to tap to power my indaglo gauges so they turn on when i turn my headlights on? there used to be a good site that showed which wire by Autotoys.com but they now only have it available if you buy something from them. anyway, any help would be great. thanks.
Does your indigay lights come with it's own dimmer switch? If so, tap directly into the 10A fuse #19 (it's labeled dash lights on the cover). I've never installed these, do the come with their own in-line fuses? If so, it's the RED/GRN wire. If no fuse is provided with your lights tap the RED/BLK wire. I just typed this in hope you are doing this on a 92-95. I have no idea on 96+.
ok on a 92-95 there was two wires for me one red and one black , i put the red wire into the fuse box with a spade clip , into the instrument backup light fuse i think , ad from there ground the black wire and your gauges should glow whenever you turn on your parking lights or headlights
