hp??
Old 01-23-2003 | 08:22 AM
oc_civic's Avatar
oc_civic
mcc racing
the "uni wiper" ruins it for me...
Old 01-23-2003 | 08:26 AM
coreyxmitchell's Avatar
coreyxmitchell
wow is that car ugly...i can't get into that stuff. i also don't think he's doing much over 300, but definitely not over 400 imo. i just don't see it being enough
Old 01-23-2003 | 08:31 AM
v4lu3s's Avatar
v4lu3s
a b18b with a blockguard, hondata, cams, and injectors can make 300+...so i would think with that much mroe work in this car it is capable of far more than 320....
ManTiS's Avatar
ManTiS
NinJA
A uni-wiper is more aerodynamic ... duh
Old 01-23-2003 | 09:57 AM
nrcooled's Avatar
nrcooled
Track whore
That car just completely plays into the "civic stereotype" All show no go.
Old 01-23-2003 | 10:59 AM
Knight2dro's Avatar
Knight2dro
my friend contacted him
he said that he had 440hp but diff engine and stuff
the specs on the site is old
Old 01-23-2003 | 02:19 PM
crucial Si's Avatar
crucial Si
Banned
i dont believe it....i dont care what the guy says.
Old 01-23-2003 | 02:28 PM
v4lu3s's Avatar
v4lu3s
i dont understand why people are so incredulous about the power?
the list below of performance parts only should be more than enough to make 440hp with the proper tuner. a local tuner built a 330+ hp civic with a b18b1, blockguard, web cams, hondata4b, and a simialr turbo kit...this guy on tha tpage has way more work into his car, all it takes is the right tunner....
- 1.8 LS / V tec conversion
- LS Bottom end balanced and blueprinted
- Custom J.E. 10:01 compression pistons
- Polished and balanced crank
- Pauter High Performance Rods
- Unorthodox Polished crank pulley
- Port and polished GSR head w/ 3 angle Valve job
- Web retainers and springs
- SI stainless valves
- ARP Head Studs
- JG Edelbrock Intake Manifold
- JG 65mm Throttle Body
- MSD Digital 6 ignition
- MSD Blaster Coil 3
- Magnecore wires
- NGK R plugs
- Paxton fuel pressure regulator
- STR fuel rail
- STR Cam Sprockets
- APEXi custom N1 3 inch exhaust
- REV Hard Block guard
- Rev Hard Hybrid Turbo Kit w/ Spearco Intercooler
- Turbonetics T3 / T04 Turbo
- Custom Mandrel Bend 3 inch IC pipes in Blue
- Tial Blow off valve
- Tial 35mm Wastegate
- MSD intank fuel pump
- Accel DFI System
- 550cc RC Engineering Injectors
Old 01-23-2003 | 02:40 PM
crucial Si's Avatar
crucial Si
Banned
- ARP Head Studs
- Magnecore wires
- NGK R plugs
- STR fuel rail
- STR Cam Sprockets
- Accel DFI System
where is the dyno sheet?
Old 01-23-2003 | 02:58 PM
Hondaman's Avatar
Hondaman
Black Pearl
What does the 440hp mean, he had it on the old engine or he has it on his current engine? Your statement is confusing.
