What short shifters actually work in a Del Sol?
JDM all day
I have heard of people buying short shifters for their Del Sols and it actually has a longer shift throw than the stock shifter. I'm looking for a short shifter that has a dramatically shorter shift throw while not thrashing my transmission nor rattling because of the bushings. I have no clue what companies make a true short shifter for the Del Sol and not just a Civic copycat. I would also like a short shifter with either the same height or lower than stock shifter height. Thanks in advance for your replies.
What I did, was take a 94+ integra Short Shifter, and cut several inches off of the top (because the integra and civic shifters are longer than the del sol's up top). I took about 3-4 inches off, and re-threaded the shifter. Throw is great... feels really solid, and is much shorter than stock.
I don't know if any of you who try this will have problems with the shifter hitting the top of your exhaust though... that will have to be looked into.
By the way... I think that OBX came out with an adjustable throw shifter, that lets you adjust where the pivot ball sits, so that you can customize the throw.... may be worth checking out.
Good Luck
Good Luck
