Strange overheating problem
Wouldn't a stuck open thermostat cause it to run cool, not hot?
The radiator cap seems to be providing pressure (if I release it slowly while hot, steam comes out as I release the spring).
I was also thinking that about testing the thermostat. Why go through the trouble for such a cheap part? Is there any difference between the $7 and $13 one? I'm not looking to save money on such a cheap part, but I'm just curious.
No heat in the winter or taking a long time for the car to warm up usually means the thermostat is stuck open. I took my thermostat out over the summer to keep the coolant flowing all the time as I was having overheating issues when autocrossing. When I put it back in around October, my car wouldn't be warmed up by the time I got to work and it's a 10 mile drive. Put the thermostat back in (before my head gasket replacement) and my car would be warmed up by the 1st street I got to (1/8th mile).
Autocross Help Page
Autocross Help Page
air bubbles big enough to fuck with the ability would heat would also make his cars IAC go up and down like crazy. Also if the ECT was fucked it would code in a 98
Already answered, but I'm pretty sure it was lack of coolant. I put a bottle of water wetter and about a quart of water and it seems to be staying cool. Honestly, I haven't been doing much driving and right now I'm halfway across the country, but I'm pretty sure that solved the problem. I assume that I have a VERY slow leak and will just continue to monitor the situation. If I get back from Las Vegas and find out that it is not fixed, I will keep you guys updated.
Thanks for all the advice and diagnosis.
My car had same effect not too long ago.. It was from lack of coolant, and your also right about the idle, if your down a little coolant, your idle will go nuts.. as i slowly added coolant, idle slowly went to normal. The 2 coolant lines that run to the heater core were the issue. One had a small slice in it, and would only leak when the engine was warm. The area that those lines are in are also tricky to observe when they are leaking.
