traction problems
Old 01-15-2003 | 06:00 PM
reddemon009's Avatar
reddemon009
Default traction problems
does any body have any ideas for better traction. i have a ex turbo and i cant hold the ground thrugh 1st n 2nd gears. i have nitto drag radials in the front 205,45,15s on rotta slip stream rims.but they dont really help. i was thinkin may be a better suspension??? i have obx coil overs n tokico struts non adj.does any one have any ideas?????
Old 01-15-2003 | 06:17 PM
96sedanR's Avatar
96sedanR
my friend has the exact same setup as you and had the same problem. heavier rims and better tires like potenza S0-3s should help
Old 01-15-2003 | 08:57 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Ever think of dropping the clutch at a lower rpm? And you have to remember, the colder the weather, the harder the tires are, and the less they'll grip...
Old 01-15-2003 | 09:18 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
lower tire pressure
Old 01-15-2003 | 10:51 PM
mrmike's Avatar
mrmike
Limited Slip Differential, wider tires
Old 01-15-2003 | 10:55 PM
Paul's Avatar
Paul
Eater of Rice
feather the clutch
Old 01-16-2003 | 04:35 AM
DRTHV8R's Avatar
DRTHV8R
Try a stiffer spring and shock set-up. I run agx's w/eibach sportlines. With the shocks set soft I spin off the line dumping the clutch @ 4000 rpm. When I set the shocks to the stiffest setting I didn't spin and reduced my 60' time by .3.
Old 01-16-2003 | 05:32 AM
crucial Si's Avatar
crucial Si
Banned
dont launch at 5grand.
Old 01-16-2003 | 05:45 AM
spanky's Avatar
spanky
I go duffy on dem bitches
lsd, stickier tires.
rwd helps too :fawk:
Old 01-16-2003 | 06:14 AM
white lightnin's Avatar
white lightnin
I lost a race once just because of traction issues. Burned all the way through second cause I was pumped up to much. Feather it out from a lower rpm.
