brake light not working
Old 02-10-2009 | 05:22 AM
Ls Fritz's Avatar
Ls Fritz
Fresh 2 da Game
Default i am havin the same issue.
last night i discovered that my breaks were not working i pulled every fuse and replaces the bad one for the gauge cluster but other than that they were all good i looked at the break switch and it looked old where can i got to get one of theses
94 civic hatch w/ ls swap
Old 02-10-2009 | 07:17 AM
Line7's Avatar
Line7
Platinum Member
dealership.
Old 02-10-2009 | 02:05 PM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by fgodmaire
i was talking about the button was not sticky or jammed
because sometimes its working
ah, sometimes it doesn't "look" like it is bad, but it is starting to fail if your brake lights are failing intermitently.
Old 02-12-2009 | 07:39 PM
cruzalekz's Avatar
cruzalekz
you could get a jumper wire and jump the brake switch. if the brake bulbs do light up, then replace the switch.
Old 02-13-2009 | 10:37 AM
Ls Fritz's Avatar
Ls Fritz
Fresh 2 da Game
ok i replace fuses th break light switch and bulbs still nothing any ideas
Old 02-13-2009 | 07:53 PM
cruzalekz's Avatar
cruzalekz
do you have a test light or a voltmeter?
the brake switch has 2 wires, one of themwill have constant 12v and the other wire should be switching from 12v to 0v as you press or depress the brake switch.
if that wire is switching from 12v to ov, then yur problem is further back to the taillights.
i just dont have a wiring diagram so i cant pin point you to the right wire color etc.:blue:
Old 02-13-2009 | 09:25 PM
Ls Fritz's Avatar
Ls Fritz
Fresh 2 da Game
that is our next move but thanx for that lil bit of info. where could i get a wire diagram.
Old 02-13-2009 | 11:52 PM
Civic2Scooby
its the brake switch.
Old 02-14-2009 | 11:49 AM
Line7's Avatar
Line7
Platinum Member
He said he replaced the switch. Get a voltmeter, test the switch you replaced. You dont need a wiring diagram, theres only two wires at the switch like cruzalekz said.
Check your wires at the bulbs, make sure theres no rips in the insulation and that theres no oxidation in the sockets where the bulb goes. Use contact cleaner and a flathead to clean the contacts.
Also, make sure you got the correct bulbs: http://www.sylvania.com/ConsumerProd...de/default.htm
Old 02-14-2009 | 12:10 PM
Civic2Scooby
I didn't see that he replaced it.
